Hello guys! Got an issue with Archetype Abasi… Not working in “mono” mode, have to switch to “stereo” but then no signal on left channel… Probably very stupid
I’m using Plini too and don’t have the same issue…
Thanks!
Hello @vanderstocken.gilles. Was your issue already solved? If not, you just need to disable the input you’re not using in the Audio Settings window.
Thanks a lot! It worked!
