Bug: Block Bug
CorOS Version: 1.01
**Blocks settings get carried over to every block on each scene in a setting it turn causing all blocks to either bypass or unbypass in every scene when I save a setting as default for the block.
  1. make 2 blocks, im my case 2 compressors
  2. bypass them on all scenes
  3. save default settings on 1 scene where the block in unbypassed and then switch to other scenes, the block will also be unbypassed on all other scenes
Hey @Bubson. Could you please send us a video to support@neuraldsp.com showing this issue?
Thanks!
Will be sending one over now
