With Control active, the Windows Media Player in the computer had several short stops until there was a big one with no return to normality and I got a Blue Screen in the computer.
Windows 10.
I restart the pc. Restart only the Media Player and it freezes at start.
Hard reset the computer.
It was ok until new Cortex Control. No other updates in the pc. It worked properly with Control Beta.
WMP seems to be working ok now but I’m scared of trying Control again.
My guess is you had some computer conflict with audio between both applications leading to the BSOD. There are multiple variables for a BSOD and highly doubt the Cortex Control application was the source of your BSOD. I would recommend to update your PC / drivers as applicable. Worst case you can email support@neuraldsp.com so that they can log your issue and hopefully help provide resolution but as of current, I haven’t heard of anyone having that issue etc.
I generally don’t connect my pc to internet because I only use it for playing, recording and producing music and I really do hate the auto update in Windows 10. It looks like there’s not a way to disable it. So I only connect to internet when it’s mandatory, that could be the problem.
Do you have the latest (currently labeled from August) Windows USB driver for the QC loaded? Click the ‘Windows’ button under the ‘Quad Cortex’ heading on the downloads page.
I installed firmware 2.3 and Cortex Control 1.0.0 this morning, and fired up Cortex Control to make sure it was all working. I then closed Cortex Control, but left the USB lead connected. Very shortly afterwards I had a Blue Screen error crash, which the log attributes to “Driver path C:\WINDOWS\System32\drivers\NeuralDSP_UsbAudio.sys”.
I have the latest version 5.58.0 installed on a fully up to date Windows 11.
