I recently updated my laptop and it is somehow on Windows 11 now when I was on 10 before. Now Cortex control is having major issues and disconnects or locks up when I change presets. Is this a known issue using Windows 11? Thanks
No, I’ve been running W11 for months with zero issues. You most likely just need to re-install the drivers and the Cortex Control again which should get you going.
Thanks, I’ll give it a go.
I didnt have too much issue with cortex control until the update before corOS 3. once that happened the audio driver constantly caused artifacts on recording and the control app would force close a lot when selecting presets from directory. it also would stop working if the computer went to sleep and upon waking id have to close cortex control and re open every time. I ended up getting a MacBook and while most all issues are resolved from the switch you still get issues where it force closes at times. it has been like this for a while and a lot of the windows side issues have been there since launch of cortex control and still haven’t been addressed. I don’t think they care to much to figure out why its so buggy
They obviously care as Cortex Control works perfectly for a larger majority of users.
