I researched about the best fast charging power banks for the past few days because I need a reliable backup charger for travel, daily use, and emergencies. I read reviews on Wirecutter, TechRadar, and Tom’s Guide, and they are recommending these two as the best:
However, I am having trouble deciding which one would best suit my needs and I need your expert advice.
I usually charge my smartphone, wireless earbuds, smartwatch, and sometimes a laptop or tablet while traveling or working outside. I need something with fast charging, long battery backup, multiple ports, and reliable performance for long-term use.
So which one should I buy? Any recommendation will be appreciated.
Con el DC7, únicamente, tendrás que utilizar 4 de sus 7 salidas. Si le añades el Crush, utilizas 1 única salida que el mismo Crush convierte a 12V. para alimentar el Quad Cortex y te quedas con el resto para tus pedales.
With the DC7 alone, you will only have to use 4 of its 7 outputs. If you add the Crush, you use a single output that the Crush itself converts to 12V to power the Quad Cortex, and you keep the rest for your pedals.
OP is asking about a power bank (or rechargeable battery system). This bit about the Cioks DC7 + Crux doesn’t address that at all.
Hey @gridif, I don’t use these battery systems, but here are a couple of threads where other users have posted about their solutions and recommendations.
