Allow IR loader to affect L or R only
The main use case for the NC (for me) would be a backup for my QC, which I currently have set up to send a pre-IR signal out of one output and a post-IR signal from the others.
If the NC could be set to send the Post-IR signal from one output, and a Pre-IR signal from the other, this would serve as a great backup unit for those using IRs with a real cab on stage.
This would (ideally) just be a configuration option that would apply to all presets and is switchable from a main menu.
I agree, that would be super useful
Super useful if you were crazy enough to use it for an acoustic as I a hoping to do. Mine comes Monday.
super useful indeed
This is a must. Don´t understand it doesn´t have 200 votes.
This device would be an ideal backup for my Quad Cortex. However, being unable to send out a cabsimmed output to FoH and simultaneous unsimmed output to an actual cab on stage is a deal breaker for me. NeuralDSP, please implement this and it’ll be an instant buy for me! Holding off for now. It seems doable, since the chain allows for stereo output, i think it should be quite easy to implement one side actually going through the cabsim and the other side just going through a NULL-sim, or whatever. :wink: Many thanks in advance!!
The update I’m waiting !
This would be ideal! Hoping it’s coming soon
100% agree with this, Im using the my quad cortex with a split to amp and front of house. And the nano cortex would be a perfect backup unit if we could split the sign exactly like this
IR to FOH
DI (no cab) to AMP Return
UPDATE:
Ola Englund asked Neural DSP, they’re working on that option !
4:48
This would be a deciding factor in converting a Helix user (HX Stomp) over to nano Cortex (currently set up with a mini board all in one, using same routing L - PowerAmp + CAP , R - IR to FOH)
