Archetype: Plini X and Archetype: Gojira X 1.0.1 are now available
Archetype: Plini X and Archetype: Gojira X 1.0.1 are now available. You can download the updates via the Downloads page.
Archetype Plini X v1.0.1
Added
  • “Maximum” window size.
  • “Tap Tempo” MIDI-learn support.
Fixed
  • An issue where creating a new plugin instance on Pro Tools loaded the default values instead of the “Default” factory preset.
  • An issue where the standalone global Tempo recalled 120BPM when relaunching the application.
  • An issue where the Tuner screen caused UI lag.
  • An issue where legacy user presets loaded wrong PAN values.
  • An issue where Reaper 7 sessions could crash during playback.
Archetype Gojira X v1.0.1
Added
  • “Tap Tempo”, “EQ’s Low/High Pass filters”, and “Mic Type” MIDI-learn support.
Fixed
  • An issue where it was not possible to type negative values in the EQ section.
  • An issue where the Cab section caused lag when using custom IRs.
Updates must be a good thing, I suppose, but is it really necessary to force the user to abort the install and uninstall the previous version before resuming the update? Feels kind of '80s to me.
Maximize window? Why couldn’t it be full screen? I have two monitors and when I use XL it looks terrible. I just want to be able to have it full screen on one monitor while other monitor is used for other music software. I was so excited for this update with the full screen option. What a disappointment.
Is anyone else having problems with Gojira X 1.0.1?
I performed a clean install of the new Gojira X update today on my Macbook Pro running Sonoma 14.4.1.
I have no input signal at all when running through my Scarlet Solo. The input/output bars don’t move at all. When I switch to the built-in mic in the plugin menu, I do get an input signal and audio processing, but when I switch back to the Solo, nothing. I have confirmed that only the audio input channel for my 1/4" jack is selected.
My guitar cable, USB cable, Scarlet Solo, and input/output configuration are working fine with Achetype Rabea, so I feel confident that it is a bug with the latest Gojira update.
I have tried multiple re-installations, restarted my laptop, did a complete shutdown, and typed in the microphone reset in the Terminal as well and still nothing. Anyone have a suggestion? Bueller?
