Archetype Cory Wong settings not working
Are you using High-DPI scaling? If that’s the case, try disabling it and check if the issue persists.
You could also try deleting the .settings file (Keep a backup of it) and then launch the application again. It should be located at: C:\Users\Your user profile\AppData\Roaming\Archetype Cory Wong
