What device are using to send the MIDI messages via bluetooth?
What functions do you control?
Bank Change?
Preset Change?
Scene Change?
Can all of the 3 items listed above be controlled by MIDI?
The website manual “suggests” - you can set the bank/preset. Is anyone doing this via wireless MIDI??
Honestly it took a few tries to pair and cant remember how I did it lol. I use an XY and EC remotes controllers. I love the compact size of this midi controller. I attach the remotes to inexpensive stainless steel money clips, which I clip to the guitar strap.
I use CME Widi (u-Host on the computer, Master on the pedalboard with the QC - check my pedalboard - Master on the bass player’s Anagram )
U-Host is the group Master (MacBook plays backing tracks, we use Logic with 1 song per project and only bounces tracks - we have all projects numbered in the setlist order and all open at the same time on the computer. I select the « next song » via a Nektar Pacer with Makie Control protocol to logic - that will probably get a Widi Master too).
I use a midi track (in mackbook+logic or Idoru P1 depending on the band) to control the following on the QC :
change presets (1 per song)
change scenes (sound changes within a song)
reset expression pedals position at start and end of songs
Set expression pedals values at certain points in the song : exp 2 is usually used as a preamp gain and sometimes I control a gradual fade in or out
Midi clock to sync time based effects per song
As you see i my board I also use a Idoru P1 backing tracks player (for my other band) which is currently hard connected to a MRCC Midi mixer (I might try to add a Widi Master and integrate it in the group. If I do that then I will most probably move the « board » Widi Master directly on the QC and make that one the Group Master).
what I am desperately missing here is implementation of Midi CC#7 on the QC to act as global volume that I will control with the far left Boss Midi volume pedal.
