Whilst the QC remains incapable of storing loops internally (come on Neural, this would be an absolute game changer if you implement this) I am having to connect an external looper to give me drum beats etc to then build loops within the QC.
I am therefore trying to trigger the external looper (Boss RC5) to play as I hit record on the QC Looper X.
I’ve mapped the midi function that will select the correct loop on the Boss using the QC ‘On Preset Load’ function and now I want to start the Boss loop playing as I hit the record switch on the QC. I’ve mapped the correct midi function to start/stop the Boss to footswitch E, which is the SAME switch that starts recording in the QC Looper X.
Sadly however the QC doesn’t send a midi message when you’re in the looper page.
Is there any good reason why this should be the case? Has anyone found a workaround for this? Is this worth a feature request? It would be incredibly useful to be able to coordinate external loopers while the QC looper remains so limited in functionality
