Amount knob for capture volume
6th assignment (all led blink) representing amount knob assigned to capture volume.
This would allow much more granular control of the preset levels in realtime in the band mix without need of your phone.
Do you know that you can do this by holding the capture button for 2-3 seconds? You‘ll go into a mode where the effect level and output level knobs are blinking slowly. In this mode, the output level knob changes the capture volume on the current preset, and the effect level knob changes the adaptive noise gate level. Press exit to go back to normal.
Not that your idea is bad, I would find it more intuitive I think.
I may be mistaken but I believe that is the capture input volume not the capture volume in the capture block of a preset.
Thank you mods!
To clarify, I’d like to be able to adjust the playback capture volume, this one, using the amount knob:
Previous replies we in regard to the input capture volume when capturing a device.
Hi sdplayer,
The capture volume for the current preset (as shown in your screenshot) is the one the previous posts are talking about!
NB you have to hold down the capture button for a couple of seconds to go into the mode where you can adjust it.
If you just press the capture button quickly, then you will go into capture mode, which is different.
Actually, it’s no longer working. I’ve tried to various 2 second presses and the capture volume (output of the capture in the signal chain) can’t be changed since the 2.2.0 update.
That‘s weird. It still works for me, just tried it. I have the latest update, nanos 2.2.1.
You might have a bug or defect, I would email support@neuraldsp.com so they can get you sorted quickly.
Ok, so I thought I was holding it… but yesterday I tried again and it worked.
Other times when I’ve had cortex control open no longer how long I held the button I saw the capture screen.
Glad you resolved it. Ok to close?
Yes , ok to close. Thanks!
