Alternative routing options, mix control blocks
Hello guys, how are you?
A few features that could be wonderful to vote and be implemented, based on live gigs during this 1 & 1/2 year using QC for all of them.
1- Rotary: It would be wonderful to have a “Mix” knob and a “Volume/output” on this block. Sometimes I need the effect, but do not want to lose the definition of the signal coming in, in other words, just the “leslie” sound. It could save the necessity of bringing a parallel path that can be used to something else. Example on the picture attached where I needed another path just to blend in. The “Volume/output” can adjust the difference perceived when activating the block, I feel it is louder engaged.
Is it possible to make something like a “long hold” function for the speed? If I want to engage the Rotary I click, if want to change the speed from fast to slow, I hold the footswitch for 1s for example (can be less).
2- Have a similar “FX loop” block, for other outputs. Example below: I want to patch some effects to my amp using the out 3 or 4 (when needed), then I need to figure out a way to do that via another split of signal. Which sometimes can be done, others it becomes impossible.
It could be a block or maybe as a node between blocks telling you where you want to send your signal. Freeing one block space to be used with another thing if needed.
4- Modes configuration:
A. awesome to have the hybrid mode. Inside it would be good to choose what I want each footswitch to do. Let’s say I want two dedicated for on/off drives, another 3 for scenes, and another 3 for modulation FXs. Then: A and B drives; C, D and H modulations; E, F and G for scenes.
B. wonderful if I could create a hybrid mode and still have the 3 modes to cycle through them. Example: Stomp, Hybrid, Scene, Preset. Or if I can configure a lot: Hybrid, Preset, Stomp.
Thank you! Hope you all enjoy some of the ideas!
Rock on,
Castelo
A few feature requests that already address these:
OK, I will delete my post. Because I was searching the feature requests and any of these had appeared for me.
Just the node thing that no one talked about as long as I could see
Thanks
