Allow for designating default amp or pedal EQ settings at time of capture
Apologies if this is has already been requested.
I would really like the ability to include a captured device’s knob settings along with the type of device and the name of the capture. It could then be saved so i (and also the QC) know what the amp, pedal, etc was set at at the time it was created.
For example…You capture an amp with the Drive, Bass, Mid, and Treble all at noon position and the master at 9 o’clock. When starting the capture, I should be able to select that it’s an amp being captured, and set the dials to be those default amp or pedal EQ amounts.
Later, when playing the amp capture, there should be marks on the tone knobs that show the noon position was the captured level for each one (IE put in a small red triangle mark above them). And, the QC should then be able to (ideally) better make changes to the sounds since the initial setting were defined at the time of Capture.
This would especially be handy for people who share captures. The person who downloads one could clearly see that Joe123 had captured the amp at with Bass at 5, Mid at 4, Treble at 7, etc so they know where they are starting from when choosing sounds.
I hope that makes sense but if not please let me know and I will try to clarify better. Thanks.
I think that’s why they added the option to include a picture on the Cloud; you can show the settings there
Thanks, was not aware of that. Would still like to see it incorporated into the unit though.
