Hey guys.
Since I control all footswitches via Ableton during live shows and usually several blocks at the same time, I asked myself “why are only 8 blocks controllable and then only via the velocity value?”
The QC would be much more versatile if you could assign more than just 8 footswitches via midi. (And no! It doesn’t work with scenes, because I combine different blocks at different times)
Also programming changes would be so much easier if you could assign a midiNOTE (e.g. C2) directly to a block in the QC, regardless of the number of footswitches on the QC, instead of working with velocity values. It takes forever and is totally confusing. Especially because the values 0=Off / 127=On don’t work… When the midi command (independent of the velocity) is received, the footswitch is simply switched on or off. So you could do it via one note anyways.
I really like the Quad Cortex and I’m already using it for 2 years now but the competition does this whole programming thing much better than Neural…
So please, expand the amount for (digital) footswitches.
