For now if I need to change the input level, I could use the global IOS setup to increase the input level, however it’s not “preset” or “scene” based, means this setup couldn’t be changed when change the scene of preset.
Yes I could insert a block to control input level but it will waste a block.
Could you please consider to add the ability that tweaking input level in the “input” setup menu when long-press the input on the grid? Then it will be able to change the input level based on different scenes.
It’s will be more efficiency if we always change guitars between different power(ex. Strat to Les Paul)
I totally agree, ideally just store all input section settings in the pre-set. E.g. switch to Mic input, phantom power, strats, High gain humbuckers, piezo etc.
