Activate / Deactivate Gigview via foot switches (even with locked touchscreen)
I found the swiping gestures to be not very responsive and I often have to swipe more than once until Gigview shows up. It would be much more useful to activate and deactivate Gigview via a footswitch. My suggestion is to use one of the up/down footswitches via long-press for this function.
This could also work with locked touchscreen so you don’t have to unlock the screen and still be able to toggle between different views when necessary.
I use a midi switcher to do this (morning star mc6) to do this and it is life changing. But requires extra gear. Would be nice to have a way built in
Great big YES!! :crossed_fingers::slightly_smiling_face:
My suggestion would be to hold the ‘Bank Up’ footswitch to toggle the I/O window on or off & to hold the ‘Bank Down’ footswitch to toggle Gig View.
I use my morningstar midi controller to do this. Would be great to add to a footswitch as the screen needs to be tried a few times before it responds to the swipe.
My Pedalboard is templeboard Solo 18 , there is no room for extra pedal . So this is must have feature
I’ve been meaning to post about this (my to-do list never gets shorter!) but you’ve beaten me to it - well said. A big :+1: from me!
If you can use a Morningstar midi footswtich to turn on gig view, you could have the QC do the same.
Just put the midi command into the QC preset. That way when you go to a preset, the preset will activate gig view automatically. The QC can send multiple midi commands when a preset loads. Some users are using that feature to automatically on the tuner, or turn off the tap tempo light, etc.
Great idea @2342 ! Activating the Gigview by holding the ‘‘Bank Up’’ footswitch would be so cool! You got my vote!
I came here to make this very suggestion. Since it’s already requested in this thread, I’ve added my vote and am making this comment to hopefully bump it back to the top for some much needed attention.
I would much rather they introduced a firmware update that uses a long-press of the Bank/Preset up and down switches for changing the Bank/Preset up or down; I’m so fed up with accidentally changing the preset halfway through a song as I try to change mode because I accidentally press the preset down a fraction of a second before I press the tuner switch
Any further info on how to do this? I’d love to include the midi for this in all my presets as I only use the QC as a live device and it’d make my life way easier.
You have to connect the QC Midi to itself for this to work; 1 midi cable (“jumper”) bridging the 2 jacks
Yeah, I found a thread with the CC codes and got this working. It’s frustrating to have to do this, but at least it’s a work around for now!
Also came to make this cery suggestion. One of the bank buttons would definitely do it for me!
Or maybe: Add the tempo an bank down as 9th and 10th preset/stomp button, while changing bank up to function as tempo/tuner. Extra long press brings buttons back to working the usual way of working.
I personally use an external tuner and would love to be able to replace the tuner button function with a gig view button
It would be very nice and usefull to have this function under a foot switch. Please do it!
Last update have this funcion press and hold BANK DOWN + TEMPO to toggle Gig View, activite this feature on gig view acess settings.
Yes, and yet this creates yet another opportunity to accidentally change preset while you are playing live (the same as a short-press of Preset Down and Tuner is used to change Mode)
Having accidentally changed preset while trying to change mode, while playing live - which is really embarrassing and really spoils your set - I’ve been asking Neural to address this with a menu option to require a LONG PRESS of the Preset change f/s, but they haven’t done anything about it so far.
Agreed. It’s good they implemented it finally. But it could and should be improved. An obvious option would be to just have the gig view as the default view. And / or have the QC open the mode it was last used in before shutdown.
