Quad Cortex already has 3 modes, Preset, Scene, and Stomp. A few simple features would dramatically expand the flexibility of using these three modes in live situations, similar to Foot Controller Layouts in Fractal Audio devices:
- Any switch can be mapped to any function in any mode
- Preset select: Bank, Preset
- Scene select: 0 to 7
- Stomp toggle: 0 to 31, referring to each block on the grid, not limited to just 8 stomp switches
- MIDI send (including to self or channel -1), Channel, CC# and Value. This allows a switch to control anything (requires item 3)
- Default mappings are as currently configured:
- Preset - select one of 8 presets in the current bank
- Scene - select scene 0 through 7
- Stomp - toggle stomp 0 through 7
- Any block parameter can be mapped to a MIDI CC message, including block bypass, assuming Quad Cortex eventually supports MIDI control of all block parameters (a must have)
- Switch assignments are global with preset overrides. This simplifies the mappings while also keeping the foot switch assignments consistent across presets unless the preset needs to change something.
Hybrid mode is no longer needed, but could be preserved with two more sets of defaults.
Here’s a yaml file that provides some examples and how the defaults would be configured to match the current modes. (I couldn’t attach this unfortunately).
# A syample yaml file for a configuration of Quad Cortex switch modes
# This would be the factory default layouts
# Bank -1 means use the current bank from the Bank Up/Down switches
# Setting bank to another number allows a switch to directly load any preset
QC-Default-Modes:
Preset-Mode:
A:
Mode: Preset
Bank: -1
Preset: 0
B:
Mode: Preset
Bank: -1
Preset: 1
C:
Mode: Preset
Bank: -1
Preset: 2
D:
Mode: Preset
Bank: -1
Preset: 3
E:
Mode: Preset
Bank: -1
Preset: 4
F:
Mode: Preset
Bank: -1
Preset: 5
G:
Mode: Preset
Bank: -1
Preset: 6
H:
Mode: Preset
Bank: -1
Preset: 7
Scene-Mode:
A:
Mode: Scene
Scene: 0
B:
Mode: Scene
Scene: 1
C:
Mode: Scene
Scene: 2
D:
Mode: Scene
Scene: 3
E:
Mode: Scene
Scene: 4
F:
Mode: Scene
Scene: 5
G:
Mode: Scene
Scene: 6
H:
Mode: Scene
Scene: 7
Stomp-Mode:
A:
Mode: Stomp
# Stomp values should refer to say blocks on the grid, not switches
# This way we can have more than 8 stomp switches
Stomp: 0
B:
Mode: Stomp
Stomp: 1
C:
Mode: Stomp
Stomp: 2
D:
Mode: Stomp
Stomp: 3
E:
Mode: Stomp
Stomp: 4
F:
Mode: Stomp
Stomp: 5
G:
Mode: Stomp
Stomp: 6
H:
Mode: Stomp
Stomp: 7
# Another example simulating both hybrid modes, which are now both
# available at the same time by switching the modes
Hybrid-Example:
# Scene/Stomp hybrid mode
Scene-Mode:
A:
Mode: Scene
Scene: 0
B:
Mode: Scene
Scene: 1
C:
Mode: Scene
Scene: 2
D:
Mode: Scene
Scene: 3
E:
Mode: Stomp
Stomp: 4
F:
Mode: Stomp
Stomp: 5
G:
Mode: Stomp
Stomp: 6
H:
Mode: Stomp
Stomp: 7
# Stomp/Scene hubrid mode
Stomp-Mode:
A:
Mode: Stomp
Stomp: 0
B:
Mode: Stomp
Stomp: 1
C:
Mode: Stomp
Stomp: 2
D:
Mode: Stomp
Stomp: 3
E:
Mode: Scene
Scene: 4
F:
Mode: Scene
Scene: 5
G:
Mode: Scene
Scene: 6
H:
Mode: Scene
Scene: 7
# An example of mixing preset, scene and stomp when in stomp mode
Mixed-Example:
# Only the stomp mode is modified
Stomp-Mode:
# The first two switches select presets
A:
Mode: Preset
Bank: 5
Preset: 2
B:
Mode: Preset
Bank: 22
Preset: 3
# the next two switches select scenes B and H
C:
Mode: Scene
Scene: 1
D:
Mode: Scene
Scene: 7
# the next two are stomp switches
E:
Mode: Stomp
Stomp: 3
F:
Mode: Stomp
Stomp: 1
# The next two send MIDI messages, to QC itself
# This assumes the MIDI CC messages and values
# Have been mapped to block parameters elsewhere
# and are just using those mappings here
G:
Mode: MIDI
Channel: -1
CC: 33
Value: 0
H:
Mode: MIDI
Channel: -1
CC: 34
Value: 127
