Hello, I have a problem. I use the Cory Wong plugin in the DAW Native Instruments Maschine (version 2.8.2). When I load any preset in the Wong plugin and then save the Maschine project, then close the project and open it again, I find that the Wong preset has changed to Default by itself. Interestingly, I have this problem only with Cory Wong plugin, but everything works fine with Abasi, Omega and Gojira - they remember the preset that was used the last before saving and closing the Maschine project. Does anyone has a similar problem? how can it be solved? / Cheers, Alexander
Hello,
Same problem here. Did you find a solution ?
No, unfortunately.
But good to know that not only I have this problem.
Which version of Maschine software do you use?
The last one 2.13.0 (R874), I’ve just bought a Maschine mikro mk3.
I’ve browsed the native instrument forum and I didn’t find a post with that topic, did you already ask there ?
By the way I’m on Win10. What’s your OS ?
I’m also windows 10.
No, I haven’t ask on native instruments forum but they will likely answer that it’s a third party software blabla, but we can create such a topic there. I would also look if they have similar topics about other VST plugins forgeting presets in Maschine.
