Finally got mine wired up with all the pieces that took forever to get in…
-Temple Duo 17 (XLR/4-Way/IEC/Locking TRS Mods)
-Cioks DC7
-QC
-Boss EV30
-Polytune 3
I had to solder the locking TRS connector, but otherwise it was a pretty simple install. If anyone knows a better way of sealing up the TRS connector on the board side, I’d be interested. I see Neutrik sells a rubber sleeve that would fit over the trs connector but I was also thinking heat shrink might work too? Right now I have it wrapped somewhat in electrical tape.
The other issue I’ve had is when I set the LED strip to “cycle” through colours, I get noise through my outputs that mimics the relay doing the cycling. If I put it to a solid colour, no noise. I should mention that if I bypass the locking trs connector and plug direct into the QC, I also have no noise, regardless of the LED strip. I am thinking it has to do maybe with the shielding (or lack thereof) on the TRS?
