What does the side-chain actually do?
Hello everyone, could someone more knowledgeable explain what exactly the side chain does?
Neural gave this example: you could sidechain an input to the adaptive gate, but position the gate at the end of a chain to reduce noise created by effects in the loop.
In practice, what does this actually mean? What would be the difference between:
Input → adaptive gate (just the old one) → amp → effects
vs
Input → amp → effects → adaptive gate (just the old one)
vs
Input → amp → effects → adaptive gate (sidechained to input)
Thanks!
This would gate any excess noise from your guitar’s pickups before going to the amp. Simple enough.
In this instance the gate triggering is at the mercy of any kind of noise (typically high frequency hiss) that may be introduced from the amp. Not ideal.
In this instance the sidechain feature allows the gate to trigger based on the input alone, but it’s cleaning up noise after the amp. Best of both worlds.
Likewise for the sidechain compressors–this is a huge win.
I can’t find it mentioned in the new 3.0 manual…anyone find the documentation?
I understand the Side-chaining on Gate and Comp, but what is it doing on the Doubler?
Tracking better as it’s using a DI signal instead of one affected by amps and effects already
My guess is it’s doubling the sound of the amp output rather than doubling the sound of the guitar going into/through the amp, which might end up less focussed?
I’ve experimented with the doubler, and the side chain trigger seems to have no audible effect on the left dry or right delayed signal. But it does make a difference in how the left and right interact somehow. I’m guessing there’s some sort of dynamics in the Doubler that is affected by whether the side chain is on and what is feeding it. But I don’t know what this effect is.
The info text on the TRIGGER parameter says “The trigger input is used for detecting sudden changes in audio signals, known as transients.” But it doesn’t say what the Doubler does with those detected transients.
Does anyone know? Maybe a slight modulation of of the delay? Maybe some impact on phase?
from Max, artist relations:
Doubler: It uses that source to detect transient information, which is then used to randomise the delay time and some eq/filters
Excellent, just what I hoped it did.
It’s mentioned but not documented.
I’ve been experimenting with the Utility Adaptive Gate (S/C) i.e side chained and settled on the following flow which, in my opinion gives the best result. It’s in all my presets now.
Guitar - anything you run before the QC - QC - pedals/od/similar fx - Amp block - Adaptive gate side chained to input - Cab block(s) - remaining fx and other things (like looper x)
