It’s right below the on/off power button. Is it a phase switch? I don’t notice anything happening when I toggle this on/off.
ø
I think it’s the phase switch (180-degree phase reverse). It should be noticeable if you’re using a second IR, but likely not if you’re only using one. Hope this helps.
That is correct, it’s the phase switch as @DiffractionCircuit indicated.
