Wah/whammy inverted setups
Can anyone help with examples of presets showing wah/whammy inverted setups using one expressions pedal with a switch? Can you bypass each per scene so I can have wah on scene A and whammy on scene B? Can’t figure this out?
Hey @rjcq2006 I just made a quick preset for you. I have the expression pedal mapped to expression pedal 2. In scene 1, the wah is on. In scene 2 the whammy is on. Search for me: sleiweke. The name of the preset is “Wah Wham Switching”
Let me know if that solves your problem.
In pedals with a switch, the switch is usually XP2- this might cause some confusion
Thanks! That helps alot!
