Hey Y’all, I’ve got a particular patch built where the volume block is always turned off. I noticed a small ‘X2’ on the on/off button of the volume block. What does this mean?
X2 and X1 (see the meter in the Level section?) are the expression pedals. The bypass is assigned to expression pedal 2 (possibly for a toe-switch, that’s how I do it), and the Level is XP1. You can unassign them if you need to; click the 3-dot menu, go to “assign expression pedal”, and you can change the assignments there.
