V2 Capture Error Excessive Silence
Hello,
Trying to capture my Sans Amp Bass driver and I am getting an error message there was an issue with the recorded audio (excessive silence). I have doubled check all connections. Any ideas?
Thank you
Youre getting levels in both in1 and in2 before initiating capture?
My first thought is the output switches on the actual pedal: “line, inst, and output” and “line, inst, xlr” (if its the same or similar to pic). I switched both all the way to the right. Hope you get it, I thought the normal captures were good. These V2 captures are exceptional!
Thank you Topherbass. I am not getting any level from in 2 while playing. I have set all switches far right and I did turn up the input level 2 and it won’t register while playing.Unfortunately I am getting the same error.
