I seem to spend a lot of my time being frustrated at the number of workarounds us QC owners need to come up with, to address the many shortcomings the QC has (some, like the preset MIDI out has at last been addressed in 3.0.0, and it’s an absolute game changer for the way I use the QC)
However, having recently started playing live again, but as a duo rather than with a full band, I’ve started looking in to how to use backing tracks and click tracks with the QC. The obvious way is to use a mixer, but I’m all about having the most streamlined rig possible, and a big part of the reason I bought a high-end unit like the QC is because I really want a device that is the best possible one-box solution. Although the QC is still a long way of this, IMHO, I was really pleased (both with myself and the QC!
) to find while I was playing around with it the other day, a really good way to add backing/click tracks.
My backing/click tracks are all recorded with the backing panned hard left and the click/voice prompts panned hard right. Cleary you don’t want the click going to front of house, so here’s my solution;
- I’m using either a mobile or tablet, and streaming backing tracks to a bluetooth receiver dongle (loads of these on Amazon, usually for people to plug in to their car audio if they don’t have a Bluetooth system in their car) plugged in to Return 1 and 2, using a splitter cable to breakout the stereo signal in to left and right.
Alternatively you can connect with a y-cable (mini stereo or USB C from the phone, to dual 1/4" mono inputs) in to the Return 1 and 2.
Another way I do it is to use a Boss RC5 looper pedal as a backing track player (I’ve saved all my backing tracks in the RC5 as wav. files). The Boss is controlled by MIDI using the Preset Midi Out functions to select the Boss backing track I want on selecting a preset in the QC. I then assign MIDI commands to a footswitch on the QC to play/stop the Boss (this is one of the most useful additions to the most recent QC firmware update, IMHO).
- I then connect everything else, like this;
Note that the although I’ve got the backing/click track going in stereo to Return 1 and 2, I’ve only got a cable plugged in to Send 1 for the sound coming out; this goes to your PA/FRFR and means that you only get the backing (ie panned left) part of the backing track going to FOH, as the other channel, the side with the click on it, isn’t connected at all.
- On the grid, this will look something like this;
In this picture;
Input 1 is guitar
Input 2 is mic/vocals
Both of these go to Output 1 and 2, or 3 and 4, whatever you prefer, but to separate speakers, to get a stereo output.
You could of course run Input 1 to Output 1 / 2 and Input 2 to Output 3 / 4, but this gives you 2 cables per speaker, so you may need a small mixer to sum those to a single output, unless the speaker can take more than one input (for example the Line 6 Powercab Plus has two inputs, whereas the Fender FR10/12 only have one) -
Return 1 is the left channel of the backing track, which is the backing itself with no click. This has a Gain block and nothing else, which allows you to pan LEFT, and goes to Send 1, so FOH only has backing.
Return 2 is the right channel, so this is the click track. This has a Gain block and nothing else, which allows you to pan RIGHT, to keep the click track of the main feed to the speakers. There is no speaker output for Return 2 as you don’t want anyone else hearing it.
Now you’re are going to monitor the click track by plugging your IEM in to the headphone output, and you can even add a y-cable here to allow you to give an IEM mix for two people (eg if you’re a singer / guitarist duo).
- And here’s the best part, which I’ve only just discovered! You can use the headphones at the same time as Output 1, 2, 3, 4, without muting those, and on the I/O page, you get something that basically works like a small mixing desk for the headphone output, which is a fantastic feature. This looks a bit like this;
So now you will get only the backing track through your speakers, and the click track will be in your right IEM, but nowhere else.
The main downside I can think of is you’ll need to use quite simple guitar rigs, as you only get one row each (8 blocks) unless you remove the mic/vocals on row 2, but then you’d only be able to use a splitter on the grid to increase the number of blocks for the guitar, as you can’t otherwise go from Row 1 to Row 2 (no, even though I posted about this recently I still don’t understand why you can’t!)
You can’t really remove either Row 3 or 4, because you need the backing / click coming in stereo, so you can split them.
I was really pleased when I worked out this was all possible on the QC, so I hope that’s a helpful write-up - and if anyone has any suggestions of how to streamline this set up that would be great to hear about!
(ps, I’ve just realised that you could actually change the output at the end of the Return 1 from Send 1 to Output 3 / 4; this means you don’t need to run a separate cable from the QC in to a speaker to get the backing tracks, as the guitar/vocals and backing are all combined on the same output…)
