The idea is, when the plugin interface is open on DAW on modo “hotchange”, use preseted keys on PC keyboard to send comands to the plugin interface, like shortcuts. For Exemple, i’m recing a video that starts amp breakup and finishs highgain, i want a simple way to change de preset, our alter the configuration (like active a boost) without use a midi controler, only using my PC keyboard.
one way to do this, is using the midi parameters, but binding a keyboard key to a group of midi commands, exemple: Active a drive, alter the amp level, turn on the delay and turn of the modulation, its a group of midi commands, when i click on key “s” (solo) the comand is send.
Thanks!
