Update without IR out Control
Now Neural did a huge update, and the possibilities now good. But i miss to general things what other devices deliver… 1. midi and expression Pedal at the same time. Now we have great Wahpedals but i can’t use it, because i need a midiswitcher and so i have to choose between midi or Expression. If Midi would work via USB C also with a Controller, the problem would be solved. 2. IRs should be switchable for each output. It’s very helpfull to have the IRs at Out A and without on Output B to use a Cab with Poweramp and the IR for FOH simultaniously. The Global on/off is ok, but nothing live player really needs.
