Unacceptably high CPU load with higher buffer settings
I have some bad CPU issues when using Cory Wong. I first noticed after I raised my buffer to begin mixing. I always raise my buffer to the maximum when I start mixing for obvious reasons.
When my buffer is 2048, Cory Wong has bad CPU issues.
When my buffer is 256, Cory Wong CPU seems OK.
At 2048, when I open the Cory Wong GUI, the CPU jumps from say, 5% to say, 40%.
LatencyMon says I’m good.
My CPU is a modern powerful machine: Intel 9900k.
I run the latest version of Ableton Live 11.
I run Windows 10 latest build.
I use the high performance power plan.
I have USB suspend disabled.
I run a RME UFX interface with the latest ASIO drivers.
Like many people, I own a TON of plugins and none of them have this issue.
CPUz reports normal operating temperatures.
I see a lot of other threads in this forum complaining about CPU issues, and many or most of them have no resolution, which is disconcerting.
Any ideas?
Bumping this. Any thoughts?
Hey, @jbone1313. Our dev team is already working on this, along with several updates for other plugins from our catalog.
Thank you for your report.
