Transpose resets when switching from clean to distorted tones on Nano Cortex
Hi everyone,
I’ve noticed a problem with the Transpose function on the Nano Cortex and I’d like to know if anyone else is experiencing the same thing — or if there’s a fix.
Here’s what’s happening:
When I switch from a clean tone (with Transpose active) to a distorted tone, the Transpose resets to 0. It doesn’t maintain the pitch setting from the previous scene or block. It works fine with clean tones, but as soon as I change to distortion, the pitch shift turns off or resets.
Things I’ve tried:
  • Saving the preset after setting the transpose
  • Disabling Global Bypass
None of these solved the issue. The Transpose just doesn’t stay active when changing from clean to distorted — even within the same preset.
Has anyone found a solution? Is this a bug or a known limitation of the Nano?
Thanks in advance for any help!
