When I play my nano cortex through a mixing console, the transpose works perfectly. Yet when I plug into an amp, I can hear my dry signal blended with the transpose signal. Any clue what I can be doing wrong ? If it’s a bug, maybe it can be added to the next update for a fixing
Has to be a routing issue, because this comes up frequently with the QC. Most of the time it’s just someone hearing their guitar strings that aren’t transposed or a routing issue in the unit
What does a routing issue mean ? Is there a way to fix this?
Also, I’ll check to see if Im just hearing my strings. Cause I was playing through a small amp, the more I think of it , the more I realize this could have actually been the case
Most likely it’s that you were hearing your guitar strings with the amp.
Routing issue would mean if the clean signal from your guitar was also being sent to the output as well for some reason
Yea it turns out I think it’s the second one, clean signal is being sent through too. Weirdly, this is happening on my joyo zombie amp too, that I’m hearing a bit of clean signal with it
