Use the other paths. Each path is a processor. By spreading the items over multiple paths the layout you have will work. It is simply taxing the first processor.
You can only have one reverb on path 1/2, and one on 3/4. The exception is Spring Reverbs. Neural has their DSP team working on changing this so you can have more.
I want to set the signal path for “wet dry wet” on QC.
Stereo wet signal is separated after cab(even I wanna put eq and filter after cab then) go to row3/4
So now,I wanna use clean, crunch,dirty captures and fazz,wah,wammy,pitch,chorus,phaser,flanger,comp,gate,etc for gapless program changing with using scene mode.But the first grit can set only 8 gears and It will be 4 after put 3 types of amp and cab because I’ve already used first mixer for separating wet dry.
I have no idea to use scene mode with “Wet Dry Wet” setting now.
Does anyone have better ideas?
