Tempo Sync Options for Modulation
When adjusting modulation settings, a user should be able to sync rates to the tap/global tempo.
Um, absolutely! Come on Neural, it’s 2021, I don’t think there’s a multi-fx on the planet that doesn’t allow for tap tempo syncing of modulation! :smirk: Should be standard in my opinion…
I can’t really argue here. Although with the old bias Trem and such built into amps you could not sync. Very cool feature but not exactly natural if you compare it to how it was done with vintage equipment. All that said it should probably be there for those that are used to using it.
Oh Yessss! Please. This is a must.
