CorOS Version: 3.0.1
Describe your issue:
The tap tempo screen locks scene/stomp changes.
This is more of an UI bug to me than a feature.
- Tap Tempo
- Change Scene
- Nothing happens
I expected this to happen:
Tap Tempo > Switch Scene > Scene changes behind the Tap Tempo screen
- Read Through the feature requests
- Hoped that one day this gets attention
- Lost hope
1 year later and they made it worse.
Before 3.2.0, when you tap tempo, it shows that screen, but you could quickly get out of this screen by clicking any footswitch not assisgned by the screen.
Now with 3.2.0, all the footswitches are being assigned by the screen, so, if you need to tap tempo in the middle of a song and then switch scene, you have to wait until the screen turns off.
Even worse: if you click any footswitch with tap tempo opened, the screen never goes away and you get stuck.
Quad cortex is a live performance gig. I’d like to understand why is the purpose of this screen for live performances.
It should be pretty easy to add a flag in settings: “Show screen when tap“ and just don’t show the screen at all
I have the same issue reported here. This is a bug, not a feature request. Please fix as it basically makes the tap tempo feature not usable live.
I’m having the same issue. I didn’t realize it was a bug until just now. I thought it was some kind of a feature that allowed you to do something with the tap/tempo while the screen was up. That screen is a real problem in a live setting. It’s great to have the tempo pop up while you’re tapping but it should disappear almost instantly. Please fix this.
Agreed. This is extremely problematic for those of us who use tempo sync on delays for example and might be adjusting tempo at any point while playing. New tempo setting should, or be able to, disappear within seconds after you stop tapping the switch. …like it did until recently.
Agreed too! This is really disturbing in live session! Please for the next update. I would appreciate.
