CorOS Version: 3.3.1
Describe your issue:
When I do engage a scene that has a MIDI command assigned to that Footswitch, the mono synth block stops and seems to reload which takes over a second.
- Assign a MIDI PC message to a footswitch for a scene with the mono synth block active
- Switch from any other scene to that scene While playing
I expected this to happen:
When I switch scenes in the same patch, I expect no dropouts in sound.
- I have tried removing the MIDI command, which eliminates the sound gap/issue.
- I have tried updating firmware
