CorOS Version: 3.0.0
Switching between scenes sometimes causes loud pop-noise. For example when switching from Scene A to B to C in preset Friedman BE50 X v.2 from the latest Staff Picks:
Can someone recreate this problem or is my unit faulty?
So in my experience if you do anything with your time based fx like delays, say 1/4 delay on scene a and 1/8d on scene b and switch you’re going to get nasty noise swells and sometimes popping. It will be even more pronounced if you have tons of knobs set to scenes and making giant changes back and forth.
I noticed the same thing, but my setting is a little bit different. I have one rhythm on scene A and B-H are scenes with FX. Scene A has a Cab Capture and the other ones have a IR Single (M). Every time I switch from A to any other scene I get a loud pop noise. When I switch from B to lets say F there is no pop, probably because of the same cab.
Getting the same issue here with one my scenes. For me all the devices are the same (different values for the knobs) but I am changing the compressor.
