wouldnt it be nice if the quad cortex could do splitters like this? This would simplify so many setups. Im really hoping theres an update that focuses on this
Already requested. Vote here:
I am a bassist and have been LOVING the unit so far. Something that could be great for routing and using DI to FOH and live cabs, or allowing for more flexible routing or parallel paths would be:
Allowing more than one set of split and merge within the same 2 lines or “Side” of the processing. For example, you’d be able to split the signal after the input and run the 2nd row parallel via A/B, crossover, or balance; then merge after say block 3. Then on the same set of two rows, split after bloc…
