shooting captures of just a preamp or pedal, if i want to hear how it sounds through a cab you have to set up the cables to do that. if i want to run a capture of it i have to switch the cables around, but then i can’t hear what it sounds like though the cab, making adjustments to EQ is all blind guess work until you
- shoot capture, save capture
- swap cables
- go back to preset mode
- pull up the new capture
just to hear how it turned out
there’s got to be an easier way for shooting preamps/pedals, some way to actually get to hear it integrated into your tone, on the level check screen before you shoot it, and also after you shot it while doing the comparison, without having to go through the whole process of reconfiguration just to be able to hear how it turned out in context
Either internal signal rerouting so you can keep the cables plugged into “capture mode” configuration but have the box reroute it’s stuff internally to run the capture return/capture through a cab block, so you can set EQ exactly how you want it in context, then immediately run the capture, then on the check screen be able to do the comparison with the reference/capture in context again.
