Set bypass state of a block across multiple scenes
This would also mitigate the complaints about default bypass state when adding or changing a device model and it gets enabled in all scenes. This is probably the single most annoying thing I’ve found about building presets on the Quad Cortex so far.
I’m thinking this could be a sub menu accessed from the three dots when a block is selected. It would display a checklist of all the scenes and you could check or uncheck to enable or bypass the block in each respective scene.
Bonus marks if you show the custom Scene labels next to each checkbox.
It does this when in stomp or preset mode
