CorOS Version: 1.3 & 1.4
Describe your issue:
When I change the scene through midi controller in stomp mode, I can’t check the on/off of the block on LED or screen and it is frozen.
- Connect midi controller in stomp mode and enter CC 43 Value, 0-7
- Press the switch on the midi controller to change the scene.
- However, the LED on the switch on the QC or Bypass on the screen set in stomp mode is frozen when I change the scene.
- then if I press another switch on the QC, the Bypass status display is not accurate and the LED switch is not correct according to the scene.
I expected this to happen:
I want to see the Bypass status as a result of the scene.
I experience the same problem in this video 9:33
