Save expression pedal assignments to Block type
Not sure if this has been covered before but it seems odd that if I choose a block that I want to assign a pedal to, then I want to change the device within that block to another model of the same device type, I lose all the assignments. So if I assign a pedal to turn on a Bad Horsie wah, using the ‘Stop’ function (only just discovered this btw, really useful to be able to turn on a pedal just by moving it and having it stay on while you sweep using the Switch Delay function) but then change to a Bubba Wah, being the same type of device you’d think it would keep the pedal assignments, but it doesn’t…
Try “set parameters to default” after you’ve assigned the XP, and do that for each wah. Should be good to go from then on.
Of course, that’s mainly for blocks you ALWAYS want a specific XP setup on
Ah, that’s a good idea! :pray:t2:
