another expression pedal related from me - let people assign expression pedal to parameters per preset rather than globally as it is know - it’s quite limiting at the moment.
There is an existing request that seems similar. If it is, let me know and I will close this request.
I’d say that is, in some limited form, possible at the moment on version 2.1.0 (you can set expression pedal to control some of the parameters, but not all). What I’m trying to say is that expression pedal assignment is currently global - so if I decide to assign epx pedal for control amount of Pre FX1 - because I’m going to use WAH in Pre FX1, then I’m stuck with that. What if I want to build another set of presets with pitch block to change tuning of the instrument and then use expression pedal to control another FX parameters? Having Expression pedal assignment defined in the preset would mitigate this, so we could have different presets with expression pedal assigned to control different parameters.
Yes, expression pedal assignment per preset only makes sense!
not sure if should be in its own ticket but would be cool to enable 2 button momentary switch OR expression pedal assignment
this is quite different than the existing ticket linked which is about which parameter within a given effect block can be assigned to the expression pedal for modification.
This feature is added! Really handy to have too.
