Save / Copy individual Effect Settings as my "Standards" Possible?
I don’t know how to save different settings of an effect.
let’s say I am creating two different EQ settings.
One pre amp
one Post Amp
I would like to save them as “my standard EQs” in order to use them later in other presets.
I can neither find a way to save them (default is only one) nor to copy them.
does someone have a solution
Did you get an answer in the meantime? I am a new QC owner. All the other modelling amps like AxeFX 3, GT-1000 and Helix can save effect settings. So this would be really sad if the QC can not do this.
presently you can only have one ‘user’ setting per effect- by using the ‘set parameters to default’
If you have the block set to your preferences and you copy it, it will paste wherever you put it with those same adjusted parameters.
Block presets are a highly requested feature, hopefully it’ll be added eventually:
OK, thank you very much for the clarification. Another highly requested feature would be for me more Zappa Presets… :wink:
