Ability to save preset setting for effects
I would like to see the ability to save preset settings for different effects and name them. They should also of course be shareable. For example, You could save multiple presets of the different drive levels of the same OD pedal and be able to recall them easily. Or, for a delay, you can have a favorite preset at dotted 8th, 1/4 , fixed time, etc
Setting defaults for a block is already a feature.
You can set 1 default for a block only. You can not save and name several “presets” or favorites of an effect. Which is why I gave the example of the different commonly used delays and or drive gain settings. You also cant share the effect settings independently.
There’s a feature request for that here: Create presets of individual blocks
