I have a temple audio board that holds my QC and an expression pedal. There’s very little room to manouver, so I have some monoprice right angle trs connectors that go from EXP1/2 from an M-Audio expression (with toe switch) to the QC’s inputs on the back.
The problem is that no matter how I arrange these cables they end up covering either the MIDI out port or the USB port, both of which I’d like to remain available for use.
a straight connector likely won’t do since I want to leave it all plugged in when I put this in the temple audio gig bag, so it can’t protrude outside the board.
Any recommendations here? I’d even consider making a custom cable to fit this need, provided I could find the right connector.
Okay, project complete! I ordered a pancake TRS connector for the expression pedal side (SPS-550) and the short barrel connector for the QC side.
The short barrel is still a tad too long, and I’m slightly concerned about the bend on the cables here, but I’ll give it some use and see how it goes.
One issue is that they don’t make the short barrel diameter small enough for the cable I got, so I layered up some shrink tubing to give the screws something to grip on.
Thanks for the recommendations! Redco audio is great.
