I’ve accidentally overwritten the default values of my Tape Delay block with the last ones I was using (I’ve accidentally hit the “Set parameters as defaults” function).
Now I lost the factory settings of the block and don’t know how to restore them (every time I add the Tape Delay block it now pops out with my “new” default settings).
Is it a bug or is there some way to restore the factory values/parameters?
Following I’ve done similar
Unfortunately, at the moment, the only workaround for this is by manually dialing the original settings for each parameter or by doing a factory reset. I’ll send your feedback to the dev team to check if it’s possible to implement a feature to return to factory defaults in the future.
Just in case, here are the factory settings of the Tape Delay block:
- Mix: 50%
- Feedback: 25%
- High pass: 100 Hz
- Low pass: 5000 Hz
- Ping Pong: Off
- Sync: On
- Sync note: 1/4
- WOW: 25%
- Flutter: 25%
- Drive: 50%
- Trails: On
