Questions about using QC as my Interface
If I use QC as my Interface , can I switch monitoring between speakers and headphone without unplugging ? I can’t find a way to do that!!
No, not switch per se but there are a few things you can do. It is fairly standard for most hardware to be setup like this.
  1. Unplug the headphones when you need to.
  2. Leave the headphones plugged in and you won’t hear them.
  3. Using the I/O settings from the top screen swipe, you can change the levels of each of the outputs. Either make the headphones zero or the outputs which feed your monitors (probably 1/2) zero.
I know but I am looking for a more fast way!
Hope Neural DSP would update something like disabling headphone output or output 1/2 with one-touch!
I have my QC XLR OUTs 1/2 going to my mixer so I can always bring them up on my monitor speakers whenever I want, I also have my headphones plugged into the QC and can listen to those when I want.
I record by frequently going back and forth between monitor and headphone which works s expected. Is that what you are referring to?
I get it. A mixer is maybe what I need.
me too!! thx for the thread was wondering.
