Would it be possible to connect a Hotone Ampero Switch to the nano cortex and switch the delay on/off and the reverb on and off?
I’m waiting for mine and I’m looking for an option to use the effects like a normal pedal.
nope. as of yet, you’d have to make different presets and switch between them
That is a pity, I thought it would be possible, because, with an expression pedal it should be working
Or am I missing something here
one expression pedal gives you one switch. you can’t make the pot part of an expression pedal a switch tho
Bonjour avez vous de problème lorsque vous changez de preset ?
Le mien mets quelques milliseconde et le son n est pas propre lors d un changement de son
