I recorded on Garageband. All garageband plugins off. Going Am Fender Strat in to input then send 1 out to Scarlett 2i2 with the input gain all the way down and instrument on.
Sounds alright to me, hearing the click though doesn’t help.
Make sure you are not clipping the input of the audio interface, that adds some harsh noise, I thought I could hear some but with the click on I’m not sure.
Why are you not using the main balanced output of the QC into one of the line inputs on the Scarlett? That would be much better for level purposes and keeping noise down using the balanced connection.
Maybe my expectations were too high. Idk it does not at all sound like a cranked 20w amp in my opinion. Sounds muddy. If I heard that on a production produced track I’d say they recorded it subpar.
Doesn’t sound terrible to me, but not great either. However, there are too many variables already. Try using the QC as standalone first:
plug your guitar and your headphones straight into the QC
set everything on the QC to default
adjust the headphone volume
Try different presets and adjust them to your guitar (gain on the amp, maybe some eq / different cab/mics)
That way you should be able to quickly get some good sounds out of it. Once you have some good sounds, put the QC back into your setup and go from there.
Sound is always subjective so if the QC always sounds bad to you, then it might not be for you. But I think that is very unlikely. Keep in mind that the QC is used by many people, including professionals. So if everything sounds shitty you either have a faulty unit or you are doing something wrong. The latter most likely is the case as it mostly is with new gear / tech.
Don’t use send 1. Instead use either the the XLR (I use out1/L) or use the 1/4" out3/L. You should have zero problems running it like that with your Focusrite. I have the exact same set up for recording with the 2i2. 0 issues and sounds amazing. Good luck!
Are these people playing the QC too? What 20w combo do you have in mind when you compare the sound? Also produced track might have a lot of EQing and other production trick applied after the recording
This does not sound trash or terrible in any sensible way. QC sound amazing, since I got mine i use it for probably 99 percent of my tones, and the only way I earn money is composing and producing music.
As others mentioned, try using Out 3/L into the 2i2. That is what I do with mine and it sounds great. Just make sure you got the input levels sorted out for that particular guitar and that you don’t have the input gain on the 2i2 too high (I have mine to ever so slightly flash yellow on heavy strums). I have direct monitor on and run into a pair of 5" JBL monitors. Sounds great.
Also sounds the same if I turn off direct monitor on the 2i2 and run the USB signal into a DAW on my Mac.
Sounds like you are clipping in your audio track. Also not sure why your click track is audible in the recording. That’s also part of the issue maybe.
open EQ section of the cab/IR block and set hi pass around 80hz and low pass around 8000hz which should un-mud the sound, it’s the same with anything digital going direct.
if you’re boosting input gain from the I/O screen turn it down or to 0db and use gain block/drives instead
Get rid of the noise gate at the input. If you need a noise gate, use one in the first block. The input noise gate kills tone and doesn’t work correctly in my opinion. Even on the lowest setting, it cuts the guitar signal drastically and removes sustain.
Why would anyone go from the outs to another interface? You’re just introducing another layer of AD conversion, there is really zero point in doing this, especially to a Scarlett 2i2. Use the USB!
came here to say the same thing. clearly most the people here have no idea what they’re doing lol, you’re the first person to say this. that’s why 90 percent of user made presets on the cortex cloud sound like shit lol. adding boosts of 9-12 db on the eq if you need to boost or cut that much something is clearly wrong somewhere else in your signal chain. sorry went off on a tangent but i just notice a lot of was cortex users have no production or tone building skills at all
