Brand new to the QC world coming from a Kemper.
I am having a bit of trouble understanding which QC output to the Laney FRFR I should use?
Do I use a balanced XLR to 1/4” cable with the XLR into output 1L running to the input of the Laney?
Do I use a straight balanced 1/4 to 1/4 TSR cable from output 3L to the input of the Laney?
I am planning on running straight to FOH from the QC but I’ll have the 212 Laney onstage as a stand alone cab/monitor and to have the ability to make last minute tweaks while the sound man is setting up.
I hope that wasn’t too confusing.
Don’t beat me up too much. I’m new! ![]()
You can use either. The advantage to XLR is that you will have less noise and can run a longer cable than with 1/4". I would suggest you run XLR to front of house and 1/4" to the Laney. I have an active DI box (temple audio) that changes the 1/4" to XLR and boosts the signal a little to the Laney. In the QC I separate the volume control so the XLR output are not affected. That means I can use the QC volume knob to adjust my monitor level and it doesn’t impact the level going to FOH.
