how to get rid of delay when disabling wah ? scene mode
Ha I had the same issue the other day. When you go into the expression menu for the wah. Where you set your minimum and maximum values there is a virtual toggle switch next to the delay knob. Mine delay was set to 600ms. I could not turn it to zero because it was greyed out. When I flipped the virtual toggle switch from latch mode the delay went away. I think the delay time was able to be adjusted as well. You want that to be zero or close to it.
Got one but use the Soul Press 2 Wah instead of the QC. Just easier to use as a stand alone, no need for scenes to go between Vol and Wah. And the Soul Press 2 Wah with the two modes and Q control is great for my playing.
